Windows XP AccessHW Outport Problem
I am using the AccessHW Port IO VIs to write to the parallel port. This
works fine on my Dell workstation with Windows XP. However, although I get
no errors when I run the program, the VIs don't work on my target computer
which is a Toshiba notebook, also with Windows XP. The parallel port
control does work on the notebook with a C++ program that I didn't write.
Any ideas?
(3,315 Views)
Hi
question: is accesshw installed on your Notebook ?
if not; find it on:
http://zone.ni.com/devzone/explprog.nsf/webmain/49664743DED6F1DA862564BC004E3A7F?opendocument&node=DZ52058_US
this might solve your problem
regards
wha
(3,315 Views)
As I mentioned in my post, I am using the AccessHW VIs so yes, it is
installed. It simply works on one XP machine but not on another.
"wha@atmel" wrote in message
news:506500000005000000F8C40000-1042324653000@exchange.ni.com...
> Hi
> if not; find it on:
> regards
> wha
(3,315 Views)
