Windows Registry Access VIs doesn't work!
I can't access to a Registry Key. For example, the VI in attchments to get printer list, gets out an empty string array.
I'm using LV 6.1 over WinXPPro.
Any one can help me?
Thank's
(3,007 Views)
I took a quick look at your code. One thing to try is to change the "security access mask" value to KEY_READ.
Doug Norman
(3,007 Views)
I was able to get my printers using your VI reading the key, HKEY_CURRENT_USER\Printer\Connections also using LabVIEW 6.1 on XP Pro.
The System\CurrentControlSet\Control\Print\Printers key is empty on my PC, so can't help there. Everything looks correct from what I can tell.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(3,007 Views)
Your vi worked fine for me. I'm using LV7 / XP Home. Are you sure the registry key exists and there is a value?
Tim
(3,007 Views)
How about rootkey:"HKEY_LOCAL_MACHINE" and key
"SYSTEM\CurrentControlSet\Control\Print\Printers"
Use Regedit to check... The key you used doesn't have any printers on my PC.
Wiebe.
"ziraf77" wrote in message
news:5065000000080000006AB70000-1073519706000@exchange.ni.com...
> Thank's
(3,007 Views)
