Windows/Labview/USB-6009 Problem
I have a USB-6009 running on Labview State Machine controlling 2 analog outputs and reading 2 analog inputs. There is also a file write in AI read state. After 2-3 hours into cycling(AI Read/AO Read States), program pops up with a generic file I/O error(6). Seems like the system is running out of resources. At this point if I try to start any windows program it will say not enough resources. I have the pictures attached for state machine cases.  I have a separate case for AI/AO Start Task(DAQ CONFIG). and a separate one for stop and clear(EXIT). I tried to start the task in AI read case but my loop time goes almost double. Out of this state machine I also have another while loop(watchdog) running at 100mS rate. Any ideas will be helpful.
(3,659 Views)
could you attach the actual VI instead of some partial images? You are using lcoal variables and that's never a good sign.
(3,608 Views)
I will wait on an actual vi. I noticed my laptop was locking up without labview running too. Found a Mcafee service(myagtsvc.exe) growing and growing. I shut it down and started the program again. Maybe this will fix my problem. Will keep you guys posted. Thanks for your help though.
(3,592 Views)
Accepted by topic author lilocomotiv
It was the Antivirus program eating up the memory. Killed it and life is good. Thanks for your help.
(3,563 Views)
