Windows IPC Options Support
The following interprocess communication (IPC) mechanisms are supported by Windows:
* Clipboard
* COM
* Data Copy
* DDE
* File Mapping
* Mailslots
* Pipes
* RPC
* Windows Sockets
It would be nice to have one thread that lists all the Microsoft Windows' Inter-Process Communications options that are viable for implementation with LabVIEW.  Searching the forum for "interprocess communication" finds various ones but others are not mentioned.  NI document "How Do I Use LabVIEW to Communicate with Other Applications?" written in 2000 lists TCP, UDP, and ActiveX.  Surely there are more...
See:
* ms-help://MS.VSCC.v90/MS.MSDNQTR.v90.en/ipc/base/interprocess_communications.htm
* http://digital.ni.com/public.nsf/allkb/B3959ED76D55A9E586256965004D8092?OpenDocument
(4,941 Views)
Hi d.w.b,
Thank you for the suggestion. I will put in a request to document the interprocess communication supported in LabVIEW.
Thanks!
Warm regards,
Karunya R
(4,916 Views)
* Clipboard
* COM
* Data Copy
* DDE
* File Mapping
* Mailslots
* Pipes
* RPC
* Windows Sockets
See:
Data Copy is supported by G Toolbox:
George Zou
(4,905 Views)
