Windows Folder properties
I want to know how to programmatically hide a folder in WIndows using LabView?
(3,335 Views)
Hi LabViewde...,
if you mean to set the hidden flag, you can use the SetFileAttributes function from the Kernel32.dll.
Mike
(3,323 Views)
hey mike
thanks for your reply,
i tried your solution, but unfortunately Labview crashes due to not enough memory space.
So what parameters should i give for the Set file attribute in the configure of dll in labview?
(3,303 Views)
Accepted by topic author LabViewdeveloper
Hi LabVIEWde...,
see the attached picture please. It shows how to call the function. You will find all possible attributes here.
Mike
(3,300 Views)
It works!!
thanx a ton mike
(3,290 Views)
