Windows 8 High Res Scaling problems
I have a windows laptop with high resolution on a 15" screen: 3200x1800.
Native resolution is close to impossible to use wih labview.
Windows has a scaling feature, and I have it set to 150%, which is excellent for me.
However, SOME projects trigger LV to go native.
That is, I will launch LV 2011 or 2013 and load the PROJ file, and all will be OK.  But when I open certain VIs, all of LV suddenly goes to native resolution, which is unusable.
Does anyone have any idea why, or what causes this?  Blank/New VIs don't cause the problem, some of the project VIs don't cause it.  It doesn't happen with every project I have.
(3,255 Views)
Myself, in order to have a pleasant LabVIEW experience, I have to have it at 100%.  But other things look better as well.
Bill
CLD
(Mid-Level minion.)
(3,225 Views)
I've had to "disable display scaling on high DPI settings" in order to get my VIs to look right.  Not sure if it fits your symptoms.   I don't recall if I had to change this setting by right-clicking on LabVIEW.exe or if I could do it at the per-VI level.
(3,215 Views)
