Windows 11 and Mathscript
A few weeks ago I upgraded to windows 11, not realizing that it would affect my use of LabVIEW. I need to use the Mathscipt module, I downloaded it and installed it, but it would not let me use it in LabVIEW. Going back to the website I realized that windows 11 is not supported by the module. Does anyone know when they will be updating it? Also, does anyone know if there are any work arounds I can do to use it?
(1,809 Views)
Downgrade back to windows 10 is probably the easiest solution. Although you are probably past the deadline by which you can do it, i think it's 14 days since upgrade that you can reverse it.
(1,763 Views)
Do you REALLY need the MathScript module? I find that most if the math can be done by using the operations on the Numeric palate
(1,731 Views)
