Window PDA/Error
Hello.
I have problem when compiling a program with Pocket PC 2003 Emulator. Errors are 'a priori' not shown but when I execute the file it appears three errors.
The errors are:
Unsupported prim – Build Path
Unsupported node – PropNodeMeth, 94852
Unsupported node – PropNodeMeth, 5184
I believe that the problem is because windows are due to open.
What do I have to do to open a file which has a name by default and that no window will be opened? I also want that when saving a file no window will be opened and, as well as opening the file, the name of this file will be redetermined.
Thus it does not work.
Greta
(3,726 Views)
(3,722 Views)
Hi Greta,
The Build Path function and property nodes are not supported by the PDA Module 7.1.
That's why you are getting the errors.
miko
(3,697 Views)
Thanks Miko for your answer.
I imagined that the problem was something like that.
I still have no solution to this problem, would you have any idea?
Greta
(3,678 Views)
