Window API Function CreateEvent Handle and LabVIEW
I have a frame grabber that uses the Windows CreateEvent function to create an event handle. This event is triggered when
a frame has been acquired and ready to be processed. Is it possible to respond to this triggered event within LabVIEW?
Any help would be greatly appreciated.
(3,801 Views)
If you have the event handle, you can use a call library node to call the WaitForSingleObject function in kernel32.dll. This will block until the event is set.
(3,796 Views)
