02-21-2008 10:40 AM
02-21-2008 12:20 PM
02-22-2008 12:35 PM
Hi Roger,
In general, the latest versions of LabVIEW will work with older versions of the DAQ drivers. However, it is certainly possible that some of the older drivers could have some conflicts.
How “old” are the driver versions that your customers are using? Specifically, what version of the driver does your customer report seeing the errors with? Is the customer using the same operating system that the original program was written for? Is the customer seeing problems upgrading the VIs from LabVIEW 6 or 7 to LabVIEW 8.5?
The suggestion to work with someone to try it out is excellent. Posting the specific driver versions seeing the conflict, might also shed some light on the issue.
