Will a Setra press tranducer be compatible with the DAQ?
I wanted to know if a Setra pressure tranducer will compatible to the DAQ or only NI products can be used with the DAQ. The model # of the Setra is 204 and can be seen on www.setra.com Thanks.
(2,393 Views)
Thank you for contacting National Instruments.
NI's DAQ products can be used to measure any real world voltage or current (within limits). This pressure sensor produces 0 - 5 Volts, so is well within the range of any of NI's DAQ boards.
Just be sure that you can the provide 22 - 30 Volts excitation voltage necessary for the sensor.
Let me know if you have futher questions.
Sincerely,
Sean C.
(2,393 Views)
