Will LabVIEW interface with PLCs an if so how?
Message 1 of 8
(3,779 Views)
You can talk to a PLC using LabVIEW. It would depend on a lot of things like what PLC you are trying to talk to, if you want to code the software. LabVIEW has some drives for PLC's already in thier toolbox. There are other companies that you can purchase VI's to talk to different companies PLS's our you can figure it out on your own. We do serial or serial to usb to talk to our Mitsubitshi PLCs. We developed the drivers by packet sniffing and wrighting the code to match. Reverse engineering. That is the hard way. So it really depends on what you are looking to do. The tool kit from LabVIEW is not free as far as I know.
Tim
GHSP
Message 2 of 8
(3,775 Views)
I am useing GEPac RX3i.  I am building a SCADA lab and I want to use LabVIEW to simulate a flow loop and have the PLC control it.  So this is possible with drivers that labVIEW already has?
Message 3 of 8
(3,771 Views)
I did a search for GE Fanuc and got all of these.
http://search.ni.com/nisearch/app/main/p/bot/no/ap/global/lang/en/pg/3/q/%20%09GE%20Fanuc
I really do not have much experience with GE Fanuc equipment. I hope this helps.
Tim
GHSP
Message 5 of 8
(3,761 Views)
Message 6 of 8
(3,754 Views)
I have some more specific information that might help you help me.  We communicate using modbus TCP and modbus seriel.  Does LabVIEW already have this set up?
Thank you for your help
Message 7 of 8
(3,751 Views)
Accepted by topic author Amanda Crosswell
I found this which is an Intro to Mobus. I am not sure if you are just looking for a place to start or if you have a more specific question.
http://zone.ni.com/devzone/cda/tut/p/id/7675
It seems to have everything listed to get you started.
Tim
GHSP
Message 8 of 8
(3,740 Views)
