06-19-2007 11:47 AM
06-20-2007 11:58 AM
Hi Ron,
Though your 8.0.1 executable may seem to work with the 8.2.1 version of lvalarms.dll, I would highly recommend against using the same dll for both applications. Mixing DLLs from different versions of LabVIEW has not necessarily been tested, and may cause unexpected behavior.
Regarding your question on the lvuste.dll file, I am not sure off hand what role this file serves. I do not believe that this DLL needs to be explicitly included when you are building your EXE. If you are experiencing a problem with the DLL, I would be glad to help you troubleshoot the issue and get your application up and running.
I hope this helps!
Casey Weltzin
