Widcomm Bluetooth Driver (Windows XP) and Labview?
Does anyone know of a Labview 7.x VI library (or any documented DLL or other Code) that would allow a labview program to obtain a list of Bluetooth devices in range from a USB bluetooth interface on Windows XP using *widcomm* bluetooth drivers.
All 3 of my Bluetooth USB interfaces (different manufacturers) use widcomm drivers and are not supported by Microsofts XP bluetooth stack, this seems to be the norm.
(3,375 Views)
From the following document, it sounds like you need the Microsoft driver if you are going to be using the device with LabVIEW and Windows XP.
Chris J
Requirements for Using Bluetooth with LabVIEW 7.1
http://digital.ni.com/public.nsf/websearch/B4C0FCC67BF4485486256F12005B6D61?OpenDocument
(3,361 Views)
Yes, I am aware that Labview supports Microsoft Bluetooth Stack, however back to my statement:
"All 3 of my Bluetooth USB interfaces (different manufacturers) use widcomm drivers and are not supported by Microsofts XP bluetooth stack, this seems to be the norm."
So I am unable to use the Microsoft Bluetooth stack.
So back to my quesiton:
Does anyone know of labview libraries that support the use the *Widcomm* Bluetooth stack ? (for those of us making up 99%+ of the usb bluetooth interface owning population).
(3,324 Views)
