09-29-2017 06:05 AM
Hi everyone!
I'd like to monitor the WiFi signal strength of an ad-hoc network I create with the NI 9191 in my labview application.
Ive been trying to use the system information via the win32 API with no chance (not an expert in dll-s and so on). So I thought that there might be a more direct approach. Does anyone know about how can I access this information in the WiFi chassis itself? There must be a property node for that, right?
If not, has anyone done this before? Whats the best approach?
Thanks in advance.
09-29-2017 07:42 AM
09-29-2017 08:53 AM
Thanks for your answer.
Yeah, that's the first thing I tried. The problem with this solution is it doesnt update, unless I clicked the network flyout (Win10).
The networks are updated when a scan is completed by your WiFi card. The netsh command you are running does not request a scan, it only displays the cached results of the last scan. Opening the network flyout updates the results because the network flyout happens to request a scan when it first opens.
There is no netsh command to request a scan like this. You would have to write some code, leveraging either the Win32 WlanScan function (C# wrappers exist if you prefer that), or the WinRT ScanAsync function.
By the way, Im using LabView 2014 ![]()
