04-01-2017 01:45 PM
Are you able to try the microsoft.com example? Does it work as expected?
04-02-2017 12:33 AM
Hi Bill, I could try to connect this RT PXI to our corporate network to do the microsoft.com test. I would need to set up proxy server details on the pxi somehow (not sure how to do that yet). Or i could take the box home and try it on my home network. But say it does return more than 4 addresses, what does that tell us?
Ideally someone out there with a PXI running RT has more than 4 ethernet ports and could check the behaviour of the str to ip function?
04-02-2017 12:10 PM
We've already established that the function can return more than four addresses, that much is true. But establishing that it can or cannot do it within the environment that you are using it in can be very valuable as a troubleshooting starting point. If you can generate a table showing when it works and when it does not, you can start establishing patterns, and the patterns usually lead you to the root cause of the issue (eventually).
04-03-2017 08:01 AM
Windows 7 x64 LabVIEW 2015 SP1 32-bit returns 5 on my machine for localhost (nothing wired to name just like Altenbach's example) several are virtual adapters.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
04-03-2017 09:24 AM
Thank you everyone for the suggestions so far. However I've found an alternative solution to using 'STR to IP'. I am hoping that someone else will be able to test 'STR to IP' on a RT system with >4 ethernet ports to determine whether it is simply my system causing the unexpected behaviour or if it is a bug in 'STR to IP'.
The alternative solution is to use the example code found in
C:\Program Files (x86)\National Instruments\LabVIEW 2016\examples\nisyscfg\Network Settings Viewer.vi.
I've successfully tested this on Windows as well as RT.
04-03-2017 11:07 AM
Glad you found a workaround. There is no LabVIEW limitation on the number of addresses returned by that method on any platform. If the list is being truncated this is most likely happening somewhere in the Pharlap network driver. I spoke briefly with the maintainers of that component and they were not aware of this issue so I filed them a defect report so that this gets followed up on.
04-03-2017 11:16 AM
Don't forget to mark your post as the solution so you can save some poor developer some heartache in the future. 😉
