Why won't my LED switch on
Hi all
Pls see my attached VI. Need your help. Why won't my LED
switch on in the false case structure condition?
Thanks!
The cat.
(3,539 Views)
Your code is inside out.  Your case structure should be inside your while loop.  You need to have your boolean set before you start running your code because the boolean switch only gets read once at the very beginning of the program.  Because you have two separate while loops, you created separate stop buttons which are confusing as to which you should press to stop the program.
(3,537 Views)
Hi Ravens fan
I did as what you told me to do. The LED that is outside the case structure and while loop still
won't work but when I add a LED inside the case structure and while loop it works.
Why is this so? Is there anything I can add to make the LED outside the case structure and while
loop to turn on?
(3,518 Views)
Accepted by topic author The cat
Hi cat,
to make booleans work you have to put them in the while loop... It's called dataflow and you can watch it in execution highlight mode Smiley Wink
You also have abused express vis (well, now I learned there's a "Relais" function!). Some boolean logic will be enough and also illustrates the irrelevance of your wiring as:
1) not(FALSE)==TRUE
2) x AND TRUE == x
Please read the manual, attend the (free) online courses (to be found in the academics section of the website) and look at the examples that come with LabView...
(3,501 Views)
Hey GerdW
Thanks! That's exactly what I wanted!
Ravens Fan, thanks for your help too!
Cheers!
(3,497 Views)
