Why won't lvsbutil create lsb from Visual Studio .NET dll?
I am attempting to create the .lsb file for a C routine I am running from Labview. My problem is I can create the dll but when I use the Labview utility 'lvsbutil' from Visual Studio .NET I get an unknown error from the custom build step. I then ran the utility from the command line and I don't get an error but I also don't get my .lsb file. I am using Labview 7.0 Professional and Visual Studio .NET 2003.
I have tried this at home on evaluation version of Labview 7.0 using Visual Studio 6.0 and it works from the command line. As a result I'm not sure my problem is Labview, Visual Studio .NET or an incompatibility between the two.
Any help is greatly appreciated.
Message 1 of 13
(4,715 Views)
I noticed you have to use the following custom build setting :
Custom build step -> General -> Command line :
directory of cintools\lvsbutil "$(TargetName)" -d "$(SolutionDir)$(OutDir)"
Custom build step -> General -> Outputs :
$(OutDir)$(TargetName).lsb
And did you set directory of cintools\lvsbmain.def in the Linker -> Input -> Module Definition File field ?
Message Edited by Raistlin on 05-07-2005 07:58 AM
Message 2 of 13
(4,708 Views)
When I started having this problem I went through the Using Exernal Code in Labview step-by-step and including the things you suggested; but alas, to no avail.
Message 3 of 13
(4,692 Views)
Also double check that you aren't building managed C++ by mistake. Go to Project Properties->General->Use Managed Extensions should be "No".
Message 4 of 13
(4,692 Views)
Still the same result.
Message 5 of 13
(4,689 Views)
Can you zip up and post your project and code?
If it is large, can you create a simple example that has the problem?
Message 6 of 13
(4,684 Views)
I have attached the VC project in a .zip file. I have changed settings from the original in 'Using Extenal Code', $WkspDir is not valid build command with .NET. I found this a while ago looking thru the log file. This is very simple code while I attempt to figure out what is wrong so don't laugh too hard.
Thanks for the help.
Message 7 of 13
(4,679 Views)
Ah. I acknowledge that the lvsbutil could use a bit more in the way of error messages. Anyway, change the arguments in your custom step to
c:\cintools\lvsbutil "$(TargetName)" -d "$(ProjectDir)$(OutDir)"
Message 8 of 13
(4,668 Views)
Worked like a champ. I really appreciate the help.
Message 9 of 13
(4,663 Views)
Does anyone know if the solution here will work with Labview 7.1 and Visual C++ 2005? I think that I've done all of the things listed here (and with Platform SDK, to allow me to build DLLs, as described here http://msdn.microsoft.com/vstudio/express/visualc/usingpsdk/), but I'm still getting that same
Project : error PRJ0019: A tool returned an error code from "Performing Custom Build Step"
I can definately give more detail, but I'm not sure what is important at the moment. I'm just trying the simple example programs in the LabView manual
Thanks!
Tim
Message 10 of 13
(4,393 Views)
