Why will a stand alone executalbe with an installer work on windows 2000 and crashes on windows xp professional?
When I run the setup.exe file on a Windows 2000 system it installs properly, but the same file run on a XP Professional system I get an error stating Fatal Error: Installation ended prematurely because of an error.
See here for more information on the specific installer I'm trying to use.
In fact I get this error for any stand alone executable I try to install on any XP machines. I am using LV 7.1. Is there a way to manually install eve
rything?
Message 1 of 12
(4,153 Views)
Sure you can Install a lv application manually. just copy the exe-file,
support files in a folder. For the runtimeengine just copy the file
lvrte.dll in the folder of your application or in the windows system folder.
Hope that helps, Niko
> an error.
> See
> HREF="http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=50650000000800000...
> use.
> manually install everything?
> Thanks
Message 2 of 12
(4,153 Views)
The problem is the installer also modifies the registry. Also, why does it not work on XP?
Message 3 of 12
(4,153 Views)
A log file would be helpful. You can create log by running msi file (not setup.exe) directly from command line using
myapp.msi /l*v c:\myapp.log
That would give more insight to what is happening in the msi.
A Rafiq
Message 4 of 12
(4,153 Views)
A Rafiq,
Here is the log. I can't make any heads or tails of it.
Message 5 of 12
(4,153 Views)
All i was able to extract from msi log is that some file is in use by the system. Can you run this on any XP machine?
What files are going into this installer?
A Rafiq
Message 6 of 12
(4,153 Views)
I do not have exprience with this issue, but did a search on the log file for occurance of "err". This line in the file stood out:
Property(C): WiseInitSpaceError = Could not create temporary file, not enough free temporary disk space. Please free up disk space and rerun this installation.
Do not know if it helps, but thought I would reply.
Message 7 of 12
(4,153 Views)
Also found these in the log
Property(C): WiseInitExistError = %s Version %s is already installed. You must uninstall the existing version before installing %s Version %s. Do you want to uninstall the existing version of %s?
AND
Property(C): WiseInitAdminError = You must have administrator rights to run this installation. Please login as an administrator and re-run this installation.
Message 8 of 12
(4,153 Views)
This cannot be run on any XP machine. To get a list of the files you would have to follow the thread I attached in the original post.
Message 9 of 12
(4,153 Views)
I'm not reinstalling a version that I'm aware of and I am the administrator.
Message 10 of 12
(4,153 Views)
