Why when i run two while loops parallel, there is a problem?
In my VI, there are two while loops and i'd like them run parallel.
The DAQ Assistant is used to collect 1 thermocouple's data which will used to control 2 relays (DAQ Assistant4) which are included in the upper while loop.
Then the DAQ Assistant 2 is used to collect another thermocouple's data which will used to control the analog output(DAQ Assistant3) which is included in the lower while loop.
The DAQ Assistant and DAQ Assistant2 are using the same module and different channels.
If i run these two while loops in seperate VIs, there is no problem. But if i run them in one VI, there is errors shows: Error-50103: The specified resource is reserved.
Does anyone know the reason causes the errors? Thank you.
Message 1 of 8
(4,136 Views)
You have two tasks trying to use the same resources (ADC, clock, possibly even channel).  That is not allowed.  Why can't you just merge the reading of the thermocouples into a single task?
Message 2 of 8
(4,132 Views)
Thank you Crossrulz. i am using two DAQ assistants to collect the data of two thermocouples. Using The same module (NI9211), different channels. Each thermocouple's data will be used seperately for each while loop. Is this allowed? Thanks alot.
Message 3 of 8
(4,119 Views)
No.  The sample clock and the ADC  on the 9211 will be needed for both tasks.  That is not allowed.  You either need another 9211 or combine into a single task.
Message 4 of 8
(4,108 Views)
Thank you. Now I understand. Do you know if i combine the two thermocouple data togehter in one, then how can i seperate them for differet purpose? Do you know which function i should use?
Message 5 of 8
(4,100 Views)
Since you are using the DAQ Assisant, Split Signal is probably the one you want.
Message 6 of 8
(4,089 Views)
Thank you. Sorry that i am confused that after i split the signals, how can i know which one is which one? Is there any rules? Smiley Very Happy
Message 7 of 8
(4,068 Views)
They come out as #1, #2, #3 in order from top to bottom.  (or 0, 1, 2, 3 if you start counting based on zero.)
Message 8 of 8
(4,062 Views)
