Why under .NET the Event Callback doesn't fire events which have a 2D-array as parameter?
Hallo,
I have noticed that the VI "Reg event callback" in LabVIEW 8, doesn't fire .NET events when as parameter is given a 2D array. To transfer such a parameter from my Assembly to Labview i have to build a helper class and pack such an array in that class. That's annoying.
Is it impossible to use events with array-parameter of more than one dimension? Such a helper class which has an array as parameter is more complicated than standalone array.
If I use such a component in my Visual Studio programm, all goes OK.
Fragment from my source code:
    // That goes through processes and fires the event (Reg event callback)
    public delegate void EventSimple(int _number);
    // That goes too
    public delegate void EventArrayDouble(double [] _array);
    // That doesn't go !! why?
    public delegate void EventArrayDouble2(double [,] _array);
    // That goes - the only way to transfer my 2Darray is to pack it in such a class (The array is public property of that class)
    public delegate void EventHelpClass(HelpClass _cla);
As attachement is the component (VS2003Std) and VIs (subfolder BadTestEvents\bin\Debug)
Thank you for any explanation
Pawel
(2,692 Views)
Well, I have to say you have discovered a bug I was unaware of. I'll do some digging to figure out what is going on, but I'm afraid in the meantime that your workaround is the best plan for now.
(2,678 Views)
I realized I never reported back on this issue and I must apologize. However, the problem did turn out to be a bug, but in the .NET framework. If you run the same VI under .NET 2.0, everything works fine.
Again, my apologies for forgetting to report back.
(2,619 Views)
