10-30-2007 10:43 AM
11-02-2007 07:48 AM
11-06-2007 02:45 AM
11-06-2007 02:46 AM
Now the last two files...
Adelina
11-06-2007 05:12 AM - edited 11-06-2007 05:16 AM
aleveque wrote:
Hi,I am working with a german version of LabVIEW 8.2 developper system. I am build executables that should be run under the english version of runtime engine. I have problems with the popup menus that are attached to frontpanel elements. I am using mixed menus with user defined item and application pre-defined items.When I am build an executable, the application pre-defined items are not automatically translated in the runtime language when the executable is started on the target computer. I found out that the translation occurs only if the default popup menu is used, not for user defined one, even if pre-defined items are used. As I have no possibility to affect the pre-defined items, how can I solve this problem? Rewriting the pre-defined items is not really a solution as it implies some LV funtions that are difficult to program and difficult to access from external point of vue.Thanks for any tip.
11-06-2007 06:25 AM
Hi Rolf,
Thank you for your answer.
I agree that LabVIEW cannot translate text automatically for me, but why LabVIEW does not handle in the same way e.g. the menu item "APP_SC_CUT_DATA" placed in a standard context menu and the same menu item "APP_SC_CUT_DATA" placed in the user defined context menu. This item cannot be modified; I mean I cannot modify the item name (in german Daten ausschneiden, in englisch Cut Data). If I create a user defined item with let say "USER_SC_CUT_DATA" object tag, I will have some "problems" to program the function that already exists.
A work around would be to simulate the selection of APP_SC_CUT_DATA and fire this special function. I do not know how to do that. The event loop only wait for an event, and with dynamically defined events it is also the same.
What do you mean?
Adelina
11-06-2007 06:42 AM - edited 11-06-2007 06:44 AM
aleveque wrote:
Hi Rolf,
What do you mean?
11-06-2007 06:59 AM
Hi Rolf,
Ok, a mix can be a problem. But then how to customize item name of application defined items? Or how fire the event without selecting it?
I have up to now no ideas.
Adelina
