Why the data updated so slow?
Hellow!
I am using "TKTDS read waveform.VI" to read waveform from the TDS 420A osilloscope,i put the "TKTDS read waveform.VI" in a While loop so that i can get the continuous measurement,i choose 60000 point ,and 5ns time base in the osilloscope,but it seems the waveform updated really slow,so are there anyway i can do to make it faster? thanks!
Message Edited by happybird on 06-20-2005 12:31 PM
(2,467 Views)
Define slow. Is it seconds, minutes, or what? Is your acquisition set for averaging or envelope? I don't think that 60000 points in a couple of seconds is unreasonable. Do you need the entire waveform? From your other post, it seemed you needed the data at the end. If so, you can specify a start point other than 0.
(2,453 Views)
