Why the Labview Function Multitone Generator.vi does not work properly?
I use Labview 6.1 and need to get the time domain representation of a signal from the outputs of the Amplitude and Phase Spectrum.vi which are: Ampl Spectrum Magn (Vrms), Ampl Spectrum Phase (radians) and df (Hertz). So, I did the following test. I generated a signal (swept-sine) then I got its frequency representation from the Amplitude and Phase Spectrum.vi. I tried to recover the waveform by the correct conversions of Vrms, radians to the input units of the Multitone Generetor.vi (V, degree, frequency array, # of samples and sample frequency), but I was unsuccessful. The wavefoms were slightly different and I don't understand why. Could you enlighten me?
(2,730 Views)
Acoustics,
Could you post this sample VI for all of the forum to look at? This will allow us to better help you in this case. Thank you.
Randy Hoskin
http://www.ni.com/ask
(2,730 Views)
