Why map sensors unable to detect sensor under Measurement category in SolidWorks (SWs)
In Labview Project Explorer, when I want to add 'map sensors' to the Solidworks model, it only detect the sensor under the 'Dimension' type shown on the FeatureManager Design Tree' on the left side.
While sensor under type 'Measurement' cannot be detect. Can anybody kindly explain why Labview cannot detect sensor under 'Measurement' type? Thanks in advance.
(2,986 Views)
I've been trying to map sensors the Measurement sensor. But it could not detect Measurement sensor. It can only detect Dimension sensor.
I can't use the Dimension sensor because it requires measurement on a plarnar surface, while my model is curved. So I need to use Measurement sensor, point to point measurement to detect the length between the two components.
It mention in Labview 2014 softmotion help that both Dimension and Measurement sensor are applicable in NI Softmotion.
But why it only detect Dimension? Do I need to insert any extra command for labview to detect Measurement sensor?
(2,952 Views)
