Hi!
I noticed that the Continuous Measurement and Logging Sample Project in LabVIEW 2012 is using strings instead of enums as queue commands. I wonder if there is any good reason for that?
Anguel
已解決! 轉到解決方案。
在 01-28-2013 07:35 AM
1. It was originally written before LV had enums.
2. The developer didn't know any better, or was in a hurry and didn't want to take the time.
Mike...
Mike...
I am not really convinced that this is the case. This is a very new template project included in the latest LV 2012 only, so #1 can't be true. Regarding #2 the project uses so complex mechanisms that I don't believe that it was done in a hurry or by people who don't know better. I believe that there must be some other reasons, e.g. that strings are easier to handle or similar, although they are not as efficient as enums...
在 01-28-2013 09:34 AM
Why do you think that a string based state machine is less efficient?
There has a been a long debate as to whether to use strings or enums in a state machine. If you care, do a search. There are pros and cons to both so pick the one you like best.
I actually Asked Simon Hogg that exact question at NIST. The answer was "From a SE standpoint the user should not need to know anything about the code it is calling. An Enum breaks that paradigm since the caller must know the type def. " or words to that effect.
在 01-28-2013 09:50 AM
Actually, that is a pretty bad answer for not using the ENUM. Using strings requires the caller to know more about the internals of teh VI since it must know teh exact strings to use. An ENUM defines the valid choices.
01-28-2013 09:57 AM - 已編輯 01-28-2013 09:58 AM
In that example the code thows an error if the string is not defined. I didn't say I agree....Only what was presented to me by the maker of the thing. From a practical approach enums are much more user friendly IMHO. But, the argument for strings does exist. I'll probably regret not persuing the conversation during break.
在 01-28-2013 09:57 AM
It is assuming you know the defintion of the enum. To do the job properly, the enum should be type def. That will bring in another slew of problems, e.g. conflict of the type definition.
Thanks for the hints. To me it looks like by using strings one can simply wire commands easier, without having to update enum typedefs. The drawback is of course the risk of typing errors. Additionally with strings one can have commands with the same name e.g. "Start" or "Stop" that perform similar things in different consumer loops. Therefore they can be typed once and wired to multiple queues and then the corresponding consumer loop knows what to do when it receives that string command from its queue.
Regarding the discussion above: Comparing strings is always slower than comparing numeric values, i.e. enums, in any language. But compared to other heavy tasks like updating front panels etc. this probably cannot be noticed.
在 01-31-2013 10:27 AM
First of all, the enum vs string debate is probably the LabVIEW version of vim vs emacs. There are good arguments on either side and I doubt there'll ever be a "winner".
A brief summary of our reasoning for the current state of the sample projects:
I'm sure there are other reasons others within NI had or saw as we vetted the templates and sample projects internally but these are my reasons. We know we can't design for every situation out there -- our goal is to get some useful templates in front of new users to make them aware of what well-thought out LabVIEW programs look like. Experienced users will know their applications better and I hope they feel free to modify what we provide or create their own templates when they feel it is necessary. (On a side note please share what you come up with -- a community of experts sharing templates would really help all of us LabVIEW users.)
Simon
