Why is my Start Button not working?
Hi guys Im New to labView
Attached is my VI,
My start button appears to be working but when i press start there is no changes to my waveform.
I am using a USB-6009
Thanks a bunch!
Prash
Message 1 of 8
(3,632 Views)
Sorry here is the VI
Message 2 of 8
(3,628 Views)
Accepted by topic author prash4
Hi, prash4,
I think you should change "mechanical action" of the Start button to non-latch mode.
Message 3 of 8
(3,614 Views)
Thank you... now another problem, waveform isnt changing as i change the voltage?
Message 4 of 8
(3,604 Views)
Hi, prash4
Where do you change the voltage? I orignally thought you just do the data acquisition.
A little confused with "the voltage changed by you".
Message 5 of 8
(3,596 Views)
Measuring the voltage through the analog inputs, changing via the power supply
Message 6 of 8
(3,591 Views)
Hi, prash4,
Do you mean you changed the signal source and didn't get the correct data?
Are the data you acquired floating arournd 0 like noise?
Do you try the NI-MAX to see if the installed hardware and the specified channel are correct and the acquisition by the "Test Panel" is O.K.?
If the NI-MAX is O.K., then debug the LabVIEW code.
Message 7 of 8
(3,574 Views)
I figured it out
Message 8 of 8
(3,528 Views)
