08-27-2021 08:17 AM
I am working with EtherCAT, I am trying to use a Keyence presence sensor. Keyence provides an XML that LabVIEW does not allow importing (attached file Original_Keyence_NU-EC1.xml). I have modified until I have been able to import it and set it in Operational mode while the Scan Engine of the cRIO is Active (attached file 6100_Keyence_NU-EC1_Rev0.04_v4.xml)
I have also attached the user's manual of Keyence's communication module.
I cannot upload .xml files, they are inside the .zip
01-19-2023 04:41 PM - edited 01-19-2023 04:42 PM
I have the same problem with a Kollmorgen drive via ethercat.
I am using Labview 2020SP1 and did not find any useful information yet. I observed that when I load the FPGA in my cRIO it provoke a fault in the drive related to the ethercat network :
| Fieldbus master has stop sending setpoints within a certain timeout values. |
After that I clear the fault in the drive and try to send some value to a PDO and receive the same warning (2147137802) that you've got. The next PDO I try to write, generate an error -2147138468.
If I find anything of interest I'll post it here.
Regards
