Why is SCPI working in NI Max but not in Labview using Visa Write?
i added in MAX a network device and by using the VISA Test Panel i can send for example *RST\n .
When doing the same in Labview i get error 0xBFFF0011
I checked in IO TRACE and the sent command are the same, also with the needed \n at the end.
But there is a difference in the logged line:
In Ni Max it says "*RST.", 5, 5"
In Labview it logs only "*RST."
What is here the problem? What is missing?
Labview says to this error:
VISA: (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system.
But the connect string is 100% correct as it selected from the resource name dropdown which shows the same instruments as in MAX.
(2,470 Views)
You most likely are not sending RST<lf> to the device but literally RST\n.
The difference is in the Display Mode. Right click on your string control or constant and select “Display \ Codes”. When you now enter \n in this string LabVIEW will use the line feed or also called new line character code, rather than literally sending \n!
Rolf Kalbermatter  My Blog
(2,460 Views)
No, it must be something else. As you can see in the screenshots of the buffer contents both commands end with 0x0A = linefeed
(2,453 Views)
NI-MAX is closed when you try to run your VI? Although that typically should give a different error. I’m however not seeing the TCP/IP port number in the resource name either and doubt that inst0 would identify that sufficiently.
(2,406 Views)
The errormessage is  the same no matter if NI MAX with the VISA Test Panel is open or not.
The connect string should be correct as it is displayed automatically in Labview when using the visa resource name constant. It is also the same as what is displayed in the instruments webpage. And also the same what is displayed in the title of the Visa test Panel.
very strange
(2,397 Views)
Accepted by topic author OnlyOne
Portnumber is only needed for socket communication...
But i switched to a socket connect string "TCPIP0::192.168.0.63::5025::SOCKET" and now its working 🙂
(2,390 Views)
