Why is LabVIEW using "Background Intelligent Transfer Service" a.k.a BITS?
I have created a LabVIEW executable. When I run it, Win 10 Task Manager shows that the Exe is using MS Background Intelligent Transfer Service (BITS).  I have never seen this before. I brought it up to my IT group and they inform me BITS could be pose a security risk. I did a little digging and found these articles
https://resources.infosecinstitute.com/topic/how-criminals-are-using-windows-background-intelligent-...
https://learn.microsoft.com/en-us/windows/win32/bits/background-intelligent-transfer-service-portal
As long as my windows is kept up to date on my development machines and all the system on which the Exe is deployed, should this be a problem? I am still curious to know why and what in my Exe is triggering this service.
Message 1 of 8
(2,679 Views)
You have not described what your LV exe does.
Quoting from the MS web site: "Background Intelligent Transfer Service (BITS) is used ... to download files from or upload files to HTTP web servers". Is your app doing that?
Message 2 of 8
(2,666 Views)
Sorry, no. My Exe does use TCPIP functions but only over to a private network on a separate ethernet card. It does not go out over internet or even on our network.
Message 3 of 8
(2,656 Views)
I will defer to someone that knows what they are talking about
Message 4 of 8
(2,644 Views)
I don't think that where it is going isn't important; it's what you are doing.  Apparently you are using HTTP to transfer files either to or from a web server, as was mentioned above.
Bill
CLD
(Mid-Level minion.)
Message 5 of 8
(2,637 Views)
I am only using TCP function to local IP addresses. I do not use any HTTP functions. I do use some DB function that do go over our domain network to retrieve stuff from the DB. I guess it's more of a generic question.  So do HTTP function use this MS BITS service?
Message 6 of 8
(2,629 Views)
Instead of links to random other pages, can you instead post a screenshot of your task manager where it show that you LabVIEW application is using BITS?
Message 7 of 8
(2,563 Views)
Yes, considered that. I had already closed the exe. When I ran it again, the BITS service was not there., meaning under my Exe in Task Manager. Very odd. I'll keep an eye on it and if I see it again, I will take a snapshot and post it. I can describe it as being indented under my Exe in the Task Manager listing under the Apps category.
Message 8 of 8
(2,539 Views)
