Why is LV deploying multiple instances of my vi to the cRIO
Here is a snipit from the Deployment Progress window when I deploy my code to a cRIO target
the vi Sump Control is set to be non-reentrant and is only called from one place in the hierarchy.
So what's up with the multiple instances???
Deploying Sump Control.vi:Instance:0
Deploying Sump Control.vi:Instance:2
Deploying Sump Control.vi:Instance:4
Deploying Sump Control.vi:Instance:3
Deploying Sump Control.vi(already deployed)
(3,529 Views)
Interesting. Is it a polymorphic VI? Any way you can share it so I can take a look?
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
(3,491 Views)
Hi Rob,
Thanks for taking a look at this problem...  The vi is called Sump Control
(3,479 Views)
Nothing in that VI points to deploying it multiple times, seems perfectly normal to me except for the 2 second wait in a 250ms timed loop Smiley Happy
One thing we can check, if you make it into an executable and then download it to target, we can FTP into the controller and see if there are actual multiple instances of this VI in the dependencies folder.
Either way, it probably isn't a huge deal.  If multiple instances are being deployed it will use a small amount of memory(check the remaining memory as it downloads to see how much) but this will most likely not make a difference.
Rob K
(3,466 Views)
