Why error in "NIReport.llb"?
Hi all!
I´m using Labview 8.0 and I having problems when I close my program. Basically I created a sub VI to print some datas and always when I want quick the program this message appears:
Print HTML Report using IE.vi has unsaved changes.
Save - All
Don´t save - All
And in the list of unsaved changes there are these changes:
.VI recompiled
.NET or Active X component modified since last VI save
What is the problem and how should I proceed to solve it?
Greetings!
(2,786 Views)
I think that this is due to your version of IE being different than the one that was available to the developer.  You can get rid of this by mass compiling the report VIs or just accepting the SAVE ALL selection.  If you have done the save all and it persists in giving you this message, you may need a different answer.
Hope that this helps,
Bob Young
(2,778 Views)
