Why don't i get any value reading from index array
I trying to build my first VI and struckleíng with getting a numeral value from my reading, just give NaN as output, but my chart works fine.
What am I doing wrong?
(2,368 Views)
Until give index value to index array it'll give output as 0th index values. Check row0 whether its having values or not.
(2,359 Views)
Hi M.,
you get a mean of NaN when the "subarray" is empty. Simple as that.
  • When reading "N chan N samples" from DAQMxRead you should provide a number of samples to read.
  • You should check the error out of DAQmxRead - already inside the loop.
  • Notice that error number found in your "Selftest" list? It has a meaning, explained easily by using an error indicator and its context menu. Read that explanation…
  • Why are there 4 DAQmx channel controls? Why not use just one control and select several channels with it?
(2,345 Views)
Your chart must have some old data. You need to tell the DAQmx Read how many data points that you want to read. Currently you are getting an empty array - and that's why you're getting the NaN.
Edited to note that GerdW beat me to the punch.
(2,336 Views)
