Why does the application do not work?
I build an application by using ther LabView7 Express application builder.
This fieldpoint VI works on the computer without any problems. When I build now an installer and install it on the target computer the application do not work.
No failure message appears.
Including the .iak and .dll files in the installer or manually in the application, have no effect.
(RealTime Engine is included in the Installer. MAX is also installed on the Target machine.(I'am not sure if this is absolutely needed))
The VI is very simple only using the Fieldpoint assistant and a indicator (for Voltage).(And of coure a while loop)
What is more needed that the application works on other computer?
(All computers are using Windows XP)
(3,129 Views)
> builder.
It's not enough to copy the Fieldpoint DLLs. You will have to install
NI-Fieldpoint software on that computer for it to work properly. the
installer does a little more than just copying the DLLs to the computer HD.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(3,128 Views)
Hello Rolf,
first of all. Thanks for helping me (I'am still learning). I will check this point. Normally the fieldpoint software must be install on the target computer, but I'am not sure..
I it's not work, I will write a comment again.
(With more detailed information.)
Cheers from Germany
Alex
(3,128 Views)
Hi what do you mean by fieldpoint assitant? is it similar to that of a DAQ aissitant?i.e it is a VI icon which enable us to select the input channel we need,and then the range of current to be used,with output that we can connect to other functions? please help us as we are stuck on this hardware for a long time.. thanks!
(2,992 Views)
