Why does ni4882273 install to x86 directory on 64 bit OS?
Hello:
I installed  ni4882273 on Windows 7 Ultimate 64 bit OS but, the files are installed at
  C:\Program Files(x86)\National Instruments\NI-488.2\
instead of the expected location
  C:\Program Files\National Instruments\NI-488.2\
A binddump of the files under NI-488.2\ revealsthat they are 32-bit
Why are these the 32 bit files?
Did I use the wrong installer?
Is there a 64 bit version of NI PCI-GPIB?
Thank you
(2,998 Views)
Accepted by topic author erco61
NI 488.2 is not a true 64 bit driver, although it is supported on 64 bit systems, the underlyeing driver components are still 32 bit. This is why the driver installs the the (x86) folder.
(2,960 Views)
