Why does my data logging program slow down after a while?
A data logging program created with Labview 5.1. Slows down after a few weeks and creates files in the Temp. directory.Computer is Siemens Scenic pro 124 MB ram and AT-MIO-16XE50 Data acquisition board. Also using Solartron Dig. probes and Fieldpoint units.
(3,676 Views)
This depends on your program code and files saving technique.
1. During program run, data, stored in memory, may fill it up to the memory end. This needs to be analysed how large your data become after some time.
2. Your logging files may grow as well, slowing down program significantly. Try to avoid very large files. Divide them for reasonable parts.
Sergey
(3,676 Views)
Make sure that you don't have any arrays, that become larger and larger
with datas you don't need any more. Yust empty them if datas are not
needed anymore.
Niko
(3,676 Views)
1) how do you know that your array's are growing?
2) Do you empty them each new loop?
Freek
(3,676 Views)
Any chance that you are using Win 95/88/ME? Those OS's have well documented
memory leaks which will consume all your available memory if an application
is run long enough. Also there are some issues of memory management within
LabView in the allocation of memory.
The solution to the first is to switch to WinNT/2K. The second will be much
more difficult.
SolidW
orks Research Partner National Instruments Alliance Member
Christopher Dubea Phone: (504) 847-2280
Vice President of Engineering Fax: (504) 847-2282
Moving Parts L.L.C. email: cdubea@movingpart.com
P. O. Box 6117 URL: http://www.movingpart.com
Slidell, LA 70469-6117
(3,676 Views)
No I am running with Windows NT
(3,676 Views)
The problem was in the open/close communication subVI. The close comm. was not inserted and this led to a graduately slowing down of the programm.
(3,676 Views)
