Hello Robroy,
The KB you mentioned explaines how to build the LV Operator Interface (OI). So, I assumed you built the LV OI and also configured the LV adapter to use the TestStandGUILVRTS server without problems.
The error you are getting may be due to missing VIs. In other words, the LabVIEW OI may not be finding all the VIs your sequence is calling.
In order to deploy sequences that call VIs, you need to first run Tools >> Assemble VIs for Runtime Distribution. This tool gets all the VIs your sequence needs and saves in a separate directory.
For more information, you may check the TestStand User Manual chapter 17, it describes how to distribute TestStand and sequences.
Roberto Piacentini
National Inst
ruments
www.ni.com/ask
