Why does my DAQ device register a voltage at any input pin that is connected?
I am using a NI USB 6211 DAQ with LabVIEW.  I am trying to send an output through one of my AO pins, which is connected to one of my AI pins.  I want to then read in the voltage from the AI pin.  However, anytime I have something wired to my AI pin, regardless of whether it is powered, it registers a voltage of 10.91 volts.  Any ideas?
Message 1 of 12
(3,558 Views)
Do you have the device set up properly?
Have you run self-tests through MAX on the device?
What do you see when you access the test panels through MAX?
CLD | CTD
LabVIEW 2011 SP1 | TestStand 4.5
Message 2 of 12
(3,546 Views)
Runnin a panel test in MAX yeilds the same results
Message 3 of 12
(3,540 Views)
Call NI tech support and determine if the device is damaged; sounds like it may be.
CLD | CTD
Message 4 of 12
(3,538 Views)
Hi
what was the result when you ran it for the FIRST time?
Did you try 'Reset Device' in MAX or by the DAQmx Reset Device function?
Regards
Freelance_LV
TestAutomation Consultant
Message 5 of 12
(3,532 Views)
Freelance,
I have tried resetting the device.  As soon as I disconnect the wire while running my measurement vi, the voltage at the input pin begins dropping back down to 0V, but instantaneously, when I touch a wire (can be connected to ground, power, or another terminal on the device) the voltage jumps back to 10.91V
Message 6 of 12
(3,529 Views)
Ok
have you tried changing the input channel that is configured?
Did you try connecting a known power supply to this input channel, to check if the input is read correctly?
say, connect a 5V dc input of a frequency generator output of 1Hz sine wave?
Regards
Freelance_LV
Message 7 of 12
(3,526 Views)
Yes, I have tried several other channels.  I have tried supplying a known DC level of 5V and have tried just shorting to ground.  Even if I just touch the wire with my finger, the read voltage suddenly jumps to 10.91V.
Message 8 of 12
(3,521 Views)
Are the grounds properly tied together?  Meaning AI Sense should be tied to the ground of your signal.
Message 9 of 12
(3,517 Views)
Crossrulz,
Just to make sure I understand - you are saying tie AI Sense, AI GND, AO GND, DGND and my power supply ground together?
Won't that create a ground loop?
Message 10 of 12
(3,514 Views)
