Why does LabVIEW Application Builder 8.0.1 create an executable that will not run?
My VI runs perfectly.  But when I generate the executable, it will not run.  I get a "File Not Found" error.  The file it can't find is "File Open+.VI" from vi.lib.  I've tried copying File Open+.vi into my project.  If still generates the same error.
(2,695 Views)
There error is coming out of FlowCal Server.  You use the current VI path to build up the file paths.  That works great in development but when you compile a VI into an exe, an extra layer is added.  See this KB http://digital.ni.com/public.nsf/websearch/FD7DE8BC8FFC256C862565F4006BE363?OpenDocument
So when its an exe you need to strip the path one more time.
(2,685 Views)
(2,678 Views)
