Why do we use open URL in default browser function? What are the uses of it?
Why do we use "open URL in default browser" function?  What are the uses of it?
Message 1 of 9
(3,529 Views)
To view a web page. What is confusing?
Message 2 of 9
(3,521 Views)
Is the default browser the front panel?
Message 3 of 9
(3,492 Views)
Hi kdm7,
This VI will open URL you specify in your default browser.
For example, you specify URL as www.ni.com and your default web browser is internet explorer.
Once you run the VI, It will open internet explorer and access www.ni.com.
TuiTui
Message 4 of 9
(3,479 Views)
Okay.
So can we keep a web button to access the www.ni.com ? So that web site opens only when button pressed?
P.S  I,m a newbie.
Message 5 of 9
(3,466 Views)
You can open any web site you want.
Message 6 of 9
(3,454 Views)
Hi Kdm7,
Yes you can create your own logic to do that. You might interest in case structure or event structure.
Below are some links for you to look through
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/structures/case-structure.html    ---- Case structure
https://www.ni.com/en/support/documentation/supplemental/06/event-driven-programming-in-labview.html           ---- Event structure
TuiTui
Message 7 of 9
(3,429 Views)
@kdm7 wrote:
Okay.
P.S  I,m a newbie.
Yes, you can also, e.g. include a help file or manual as html and open that in the browser.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 9
(3,409 Views)
Hi i am working in a project where i have sevral URL to be executed one by one. I am using open url in default browser to execute it but each time i execut one a new window is opened . the question is how can i execute all this url in the window and the same tab
cordially
M.safeouene
Message 9 of 9
(3,225 Views)
