Why do I see,Setup.exe is not a valid Win32 application when I try to install an application created with app. builder 6.1?
When create an application and installer with app. builder 6.1 and try to install I get, Setup exe is not a valid Win32 application.
(4,832 Views)
Have you tried rebuilding your application and trying on a different machine or running from a different location? Does this only happen on specific operating systems? I would try building an executable out of a simple example program and running it on a machine with the LabVIEW Run-Time Engine V. 6.1. If this continues to give you the same error, maybe including your build script would help.
Jim Cahow
(4,832 Views)
Yes I have tried to rebuild the application. I have also had the same problem with all other applications. The problem started when I upgraded to 6.1. All the applications created in 6.0 install fine. There seems to be a problem with the setup exe. that is created.I have also tried to install on other machines, with no luck.The applications run fine when copied to a machine with runtime6.1.
(4,832 Views)
Are you attempting to install the built app from your hard drive on the same machine on which you have built the app?
(4,832 Views)
Spaz,
No. I build the application with an installer and burn it on a cd. Then I try to install the application on another machine.The other machine has an application created with v6.0 and runtime 6.This is also a different application.
Ed
(4,832 Views)
Because of the CD installation, I am going to take a wild stab here. Recently had the same error message installing my son's new Scooby Doo software and didn't have time to run it down. When I saw your question I subscribed to see what came up. Since then I checked out the faq's for scooby doo support. Nothing. Then I searched their web site for 'Setup.exe and win32' and got this http://www.riverdeep.net/support/faqs/l/lrntspkngl1120.jhtml
They blame a similar message with their software on "CD-ROM drive is incapable of opening enough files from the CD-ROM to install the program. This generally occurs on only one model of CD-ROM drive made by Matsushita". They also reference Win95 but my problem popped up in Win 98 and I do
have a Matsushita drive.
I tried to drill down on this in the MS knowledge base but couldn't find anything fast. There are many hits on the 'not a valid win32 application'. Most deal with their products, but the jist of it is that there are things outside of LV that can cause this error message.
I would try to install the software from your hard drive first and see what happens.
If it installs ok then http://support.microsoft.com/default.aspx?scid=kb;en-us;Q218617 (How to Troubleshoot CD-ROM or DVD-ROM Read Issues (Q218617)) might be a good place to start.
Rahts of Ruck, Shaggy!
(4,832 Views)
Spaz,
The application does install from the hard drive.So I guess the problem is with the cd-rom or the cd I create.Thanks for the feedback
(4,832 Views)
