Why do I get this error when running my executable?
Why do I get this error when running my executable? attached imagesErrores instalador.PNG
Es un placer echar una mano siempre( Base de una sana convivencia). Si mi respuesta te sirve por favor agradecemelo con un Kudo 🙂
Un especial saludo a mis hermanos latinos. Un mundo mejor es posible.
Message 1 of 11
(4,425 Views)
Is the source code working fine? Are you running the Exe in the same developement PC where you have developed the code?
Message 2 of 11
(4,410 Views)
Yes, the code is working fine. No problem. Is the failing executable. I am using the same PC.
Message 3 of 11
(4,406 Views)
Hi Jorge81,
For Error 56 it may be the reason that 'bytes to read' should be at correct limit and make sure, before reading the data whether timeout elapsed or not.... Otherwise check here
Message 4 of 11
(4,389 Views)
Error 56 is now solved.
The problem is the other error nimc.fb.straightLineMove.startStraightLineMove.axis.modeAbsolute.0.vi
Do I have to add something here?
Message 5 of 11
(4,378 Views)
Are you calling the VI dyanmically? if yes then you may have to define a common path where both the code and the exe fetch the VI.
Message 6 of 11
(4,373 Views)
Could you make me a simple explanation. I'm not sure I understand. how to do that? I am sorry. It is the first time.
Message 7 of 11
(4,365 Views)
If you are calling a VI dynamically:
  • Have the dynamic VI in a seperate folder (lets say the folder name "Dynamic")
  • Have this folder in the same folder where the Project file (.lvproj) resides
  • Where ever you call this VI use the primitive "Application Directory" path and then build the file path as "Dynamic/XXX.vi"
  • While creating the exe file go to the Destination and a create a directory name "Dynamic"
  • Then go to the "Source File setting" and select the "XXX.vi" and set the "Destination" to "Dynamic" (From the drop down menu)
  • Go to preview and check the "Dynamic" folder is created and the "XXX.vi" is inside that. Then you are good to go
Message 8 of 11
(4,359 Views)
I understand. The problem is I'm not sure that (Although it is possible that it could be). My project communicates with solidwork (CAD design).
With LabVIEW I have no error. Run well.
When did the "Aplication.exe" and give to Run
Message 9 of 11
(4,338 Views)
After performing the executable.
The installer gives me the error I mentioned above this thread. Besides asking me for a file shared Libraries (*. Dll) and then gives me other errors.
and do not let me run the program.
If not well understood maybe you can make a video explaining
Message 10 of 11
(4,330 Views)
