Why can't I set breakpoints on a vi
I'm trying to set a breakpoint on a VI (clone) and I can't.  I can't even probe the lines so I suspect it must have something to do with the VIs properties but I'm not sure where to look.  Any ideas?
Thanks in advance,
Steve
(5,577 Views)
Maybe you have debugging disabled (in execution properties)?
(5,572 Views)
Thanks alot!  In my defence I'm sorting through code that someone else wrote. 🙂
Perhaps you could explain why someone would disallow debugging in the first place?
(5,566 Views)
Code is slightly smaller and executes slightly faster with Debugging disabled. So after the code is working and thoroughly tested debugging may be disabled if the highest possible performance is required.
Lynn
(5,562 Views)
Thanks for the response folks.
(5,550 Views)
