Why I use Serial communication in LabView it will run like a loop but I don't create a loop
I don't see where you are saving data.
Check to see if the number of bytes equals zero and use that to drive a case structure where you either do save or don't save your data.
Message 11 of 16
(722 Views)
@thecone wrote:
I try to add an resgister to save the data but I have a problem. When the period is less than the delay time I send from my PIC. the data receive will equal 0. I can not save the data when it do that.
Can you help me to fix that
You have not done a single thing that I suggested. That shift register makes no sense to me. What do you think it is supposed to do?
Message 12 of 16
(717 Views)
Sorry I am new with LabVIEW.
I can save the data when I use the local variable. But I don't want to use this. Can you help me another way to store and display the data when the period is less than the delay time my PIC send ( the data will be zero if the period is less than the delay time ).
Here I try to use the shift resgister but I doesn't work.
Message 13 of 16
(701 Views)
Your shift register does not make any sense. Try this mod.
Message 14 of 16
(694 Views)
Your mod is great.
I reversed the table to see the new data update.
Message 15 of 16
(678 Views)
When my period is larger than the delay time data send from my PIC. How I can get only the lasted data ? (But do not use shift register or variable)
Can you help me? Smiley Sad
Message 16 of 16
(662 Views)
