Why I builded program display a loading dialog?
I builded a exe program use labview,the program include a lot of vi, the build is successful,and the exe program run is ok,but when the program is loading display a load dialog,how can I setting would not display the dialog?
Message 1 of 13
(3,679 Views)
I dont think any setting like there exists. It displays the dialouge box because it takes long time to load. Its for our ack only
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 13
(3,662 Views)
A program is, simplified, a zip-file of VI's. Thus the program must load all files just like when opening them in the development environment.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 13
(3,651 Views)
Thanks!!
Message 4 of 13
(3,647 Views)
Thanks!It's means when I build a big program, the dialog box will display, no way to change the display? Or can it show another picture? I think when a exe program loading, showing this box is a little strange. haha
Message 5 of 13
(3,645 Views)
You can create a splash/launcher that's a small vi showing a nice screen which launches the main program through VI server.
/Y
Qestit Systems
Message 6 of 13
(3,631 Views)
yea,it's I wish,but how to creat splash?thanks!
Message 7 of 13
(3,626 Views)
Look at attached picture, it should get you started.
/Y
Qestit Systems
Message 8 of 13
(3,624 Views)
oh, it's run a spash vi at program run,I have do this,but the loading box is running before,I think no way can change it,so thanks~~
Message 9 of 13
(3,619 Views)
Really? I dont get any loading screen if i use file path. (Maybe Lv version dependant)
/Y
Qestit Systems
Message 10 of 13
(3,614 Views)
