Why DB Tools Execute Query can't work correctly?
I connect to a MS access database using Database Connectivity Toolset(Version 1.0.1).But I can't select the certain data useing DB Tools Execute Query.I have set condition statement to the SQL query (for example:SELECT * FROM testdata WHERE "date=2004-3-12"),but i received all the data of database. That is to say,the condition statement doesn't work.What's wrong?
(2,985 Views)
when i use DB Tools Select Data node,the same problem visit me.I set condition statement to the "optional clause",I have received all the data in the DB.
(2,985 Views)
Hello cnxht,
Thank you for your question regarding the DB Connectivity Toolset. You mentioned that you were trying to use the DB Tools Execute Query.vi but you can�t select certain data in a MS access database using the SQL that you mentioned. You may want to use single quotes around the �2004-3-12� string. The following is an example from the sqlcourse website that might help.
This will only select rows where the first name equals 'Eric' exactly.
select * from empinfo
where first = 'Eric';
For more information on SQL, take a look at the following website:
http://www.sqlcourse.com/
Other resources can be found on the ni.com website by clicking the support tab at the top of the home page. Then search from Technical Resources at the top of t
he page for your topic. I hope these resources help! Let me know if you need any other support with this issue.
Shea C.
Applications Engineering
(2,985 Views)
