While loops
Please do not attach a new VI that has exactly the same name as a different VI posted earlier!
Message 11 of 34
(986 Views)
@alhabeeb wrote:
I figured it out but it kind of a mess because I need to convert the current to mass flow rate by this formula
Flow Rate=(Measured Current_mA4mA)/16mA.
Any way to organize it more?
Is the result correct?
Why do you have two identical diagram constant each if one each would be sufficient? You can branch the wire!
Message 12 of 34
(984 Views)
That piece of code you can create a sub-vi, and reuse it everytime you need to convert the mA readings into Flow
Message 13 of 34
(980 Views)
I branced them as shown in the attached VI.
Message 14 of 34
(972 Views)
Yes it could be.
Message 15 of 34
(971 Views)
Done correctly, you can just incorporate the correct scaling of m_sec and m-prim into the array diagram constants outside the loop. You also need to decide how to chart and save things. You should append the ER to the 1D array for saving and you should also decide if you want three charts (currently, two of these unscaled "m_..." values will show on the P chart, not something that makes a lot of sense.
Message 16 of 34
(974 Views)
Here's what I might do for the math using simulated data. (I could not deal with your disorganized front panel, but you should figure it out.
Message 17 of 34
(965 Views)
-Yes, I want also to chart m_sec, m_prim and ER.
- Your code has no control for the target time!
- Also, I want to indicate the all values in numerics and charts.
- To be honest, I didn't understand how did you scale the m_sec and m_prim ^_^
Thanks a lot
Alhabeeb
Message 18 of 34
(932 Views)
ALAHBEEB​
So it's a typical 4-20mA module? Usually that's the normalization, then you need to scale it to the original range.
Qestit Systems
Certified-LabVIEW-Developer
Message 19 of 34
(909 Views)
I was demonstrating the scaling and intentionally left out the target time. You already figured out how to deal with it with just a comparison and case structures. No need to leave that in, cluttering the code. Same with all your indicators. It would be much easier to use arrays of indicators for each class.
If you want to chart these three values, you need to decide where (P chart? T chart? A third chart? Two more charts? Second Y scales?). I cannot make that decision for you.
I always assume that you are honest, no need to state that. Scaling is just a linear mapping and you can calculate what the constants should be from first principles. That's what I did. In your old code, you scaled twice in a row, first by multiplying by 1 and adding zero, then subtracting 0.004 and dividing by 0.016. This is the same as multiplying by 62.5 (1/0.016) and adding -0.000064 (-1 x 0.016 x 0.004). Right?
Message 20 of 34
(883 Views)
