While loop timing control does not work
I am currently running a co-simulation using multisim.
 I don't know how this happened, but the while loop timing control in my FPGA file stopped working all the sudden.
I set the control_dT as 1200 as can be seen in the attached picture, but the output dT comes out as 40000. I also get the same way too high output no matter what kind of values I put in.
I've not changed anything in terms of control, and same thing happens for other FPGA files.
Is it possible that I accidently changed some settings????
(3,044 Views)
Which of the two loops stop?  If you are running the FPGA VI in simulation mode you could probe it or even use sampling probes.
ALE Consultants
(3,007 Views)
How long does it take to execute the contents of the loop? You cannot go faster than that. What does the subVI do? What hardware is this running on?
(2,995 Views)
