While loop problem
I have put a daq assistant in a while loop the measure a votlage. The iteration of the loop is set to be every 500 mS. The numeric indicator functions fine inside the loop. However, I can't get that value outside the loop. I thought every time the loop had done an iteration, you could get that value outside that loop? Could anybody help me? I need that value to wright it to a file at a different frequency than the while loop contraining the daq assistant. And also make an average of the value with the last 2 values.I have attached my very simple VI file.
Any help would be really great.
marc
Message 1 of 8
(3,862 Views)
Hello Marc,
I think yo forgot to attach your file...
Anyway, data id only accessible from outside the loop (on the tunnel) after it is over.
You have to build another loop in parallel to this one and send the data there - to do this you have a lot of possible ways (variables, queues, user event structures, ...)
I attach a simple example with queues.
Hope it helps,
Paulo
Message 2 of 8
(3,858 Views)
Hi Marc,
I'm not sure, but try using property node set to 'value'
My records show an answer from someone called Thomas (handle 'becktho') in which use of Notifiers was suggested. This also allows you to exchange a value between your two loops.
I am attaching the image that accompanied that discussion.
Hope this helps.
- Gurdas
Gurdas Sandhu, Ph.D.
ORISE Research Fellow at US EPA
Message 3 of 8
(3,845 Views)
Hi Gurdas,
Thanks a lot for your help, I'll try that too.
Marc.
Message 4 of 8
(3,824 Views)
In my opinion, the simplest way to do this is to use a local variable. Here is an example that also calculates the average of the last two values.
- tbob
Inventor of the WORM Global
Message 5 of 8
(3,813 Views)
Oops, forgot the attachment.
- tbob
Message 6 of 8
(3,812 Views)
oops #2, try again sleepy head...
- tbob
Message 7 of 8
(3,807 Views)
Hello Paulo,
You have really helped me, thanks. I've attached, I hope, the VI I created with your solution. If you have the time to look at it, don't hesitate to give anykind of advice. Out of my loop that gives an average of the voltage every 100 ms, I want to wright only one voltage average every 500 mS, and it must be the most recent one (not the one that was queued up at t=200 mS). I am not actually sure of what I am writing.
Thanks again for your help,
regards, Marc
Message 8 of 8
(3,804 Views)
