While loop does not exit and LabVIEW hangs
I have a while loop with an event handler inside.
When the OK button is pressed and the OK event is called, this sends a TRUE to the loop exit condition.
But sometimes (it's not consistent) at this point LabVIEW just 'stops' and it doesn't seem to exit the loop.
Although not in the picture below I placed a true/false case structure just before the loop exit with some debug to a file- so I know the data flow leaves the event handler and is on the wire that goes to the exit condition. But after the case structure everything just stops and the VI seems to go into no man's land.
There seem to be other problems like this on the forum, but I can't see anything that applies to my situation.
Is there a list of potential reasons why a loop won't exit or the VI will seem to just stop working?
Ronnie
TestStand 4.2.1, LabVIEW 2009, LabWindows/CVI 2009
Message 1 of 12
(6,416 Views)
Do you have parallel loops in your code? If so, are all the loops exiting? This sounds like a classic case of not propigating the exit to all running loops. If they don't all exit then you will be left in a state like the one you described. Beyond that it is hard to say what could be happening since we are only seeing a very small portion of the code.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 12
(6,412 Views)
Does it still hang when you disable the code (the "ESRT LOG TO FILE" vi) inside the OK Button case?
Richard
Message 3 of 12
(6,392 Views)
I know I haven't given you much to work with - but there are no parallel loops, and the ESRT LOG TO FILE vi is there as a trace to try and debug the problem.
Message 4 of 12
(6,379 Views)
Turn on Highlight Execution (Light Bulb on Block Diagram Window) and run it.
Message 5 of 12
(6,376 Views)
Just as a test, I would wire the OK button directly to the Stop terminal and act on the True condition (rather than using the constant), and I'd read this.
Richard
Message 6 of 12
(6,281 Views)
Additional to this points: If the issue persists, could you please post a detailed description with information about what exactly happens if the loop does not stop. And, if possible, attach the code to this post then.
Norbert
Norbert
Expert: Geometry
Message 7 of 12
(6,274 Views)
As Norbert mentionned, if you attach your code, we can run it and see if the same behavior occurs.
Or see why that behavior occurs.
Message 8 of 12
(6,269 Views)
Thanks for all your comments and advice - I'll try them out. One thing I didn't mention was that this VI is being called from TestStand. When it (the VI) refuses to work - then it will never work again until I exit TestStand and begin again. Then all is well for a while.
I wondered if it had anything to do with a memory leak, so I'm looking carefully at that - but haven't seen anything yet.
Thanks again,
Ronnie
Message 9 of 12
(6,235 Views)
Hi Ronnie,
If you run the VI on it's own (instead of calling it from TestStand), do you see the same thing happening? Or does it only happen when called from TestStand?
Message 10 of 12
(6,210 Views)
